due to wall function, continue refining mesh until when |
January 16, 2010, 14:50 |
Fatema Zandi Goharrizi
Rep Power: 17 |
Hi
I'm doing a free surface flow CFD modeling project that the velocity and pressure near the bottom (wall boundary) are important parameters. for evaluating the pressure result I have data and after refining mesh I saw that the pressur was not sensitive to it and I reached to a good answer. but for velocity I do not have any data and just want to reach an answer that not depedent on mesh size. I use k-epsilon standard in CFX code so my limitation for y+ is 20 and 100 (CFX help)
January 16, 2010, 16:21 |
Rep Power: 143 |
I would switch to the SST turbulence model then you can use the scalable automatic wall functions. Then it would matter when y+ goes under 11 and you can refine as much as you like.
Is there a reason you wish to use k-e? |
January 17, 2010, 06:59 |
Rep Power: 17 |
Dear G. Horrocks Salam
and thanks a lot actually my masters insist on it maybe they're not so friendly with low Rey models. I'm not too! they said the k-e is sufficient for my case. by the way
January 17, 2010, 16:20 |
Rep Power: 143 |
SST is not a low Reynolds number turbulence model! It is a general purpose turbulence model and works well for a wider range of flows than k-e. If you are having problems with mesh refinement in k-e then I recommend you go to SST as the wall function issue is not a problem for SST.
As for whether the change in turbulence model will affect things - how can I possibly know that? You have not described at all what you are doing. It is straightforward to work that out for yourself - do a test run using SST and find out for yourself whether it makes a difference. For most flows it takes the same run time as k-e and converges the same so it should be a easy test to do. |
January 18, 2010, 02:53 |
Rep Power: 17 |
thank you very much from your advice
January 18, 2010, 09:16 |
Paulo Alexandre Costa Rocha
Rep Power: 17 |
January 18, 2010, 13:29 |
Rep Power: 17 |
January 18, 2010, 16:47 |
Rep Power: 143 |
Why use k-e at all? Just use SST then you don't have any issues about wall functions with mesh refinement. The SST model has superseded the k-e model for most general applications.
January 23, 2010, 04:16 |
#9 |
Rep Power: 17 |
thank you, nice of you
independent result, k-epsilon, refining mesh, yplus |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
OpenFoam 14 installation problem | gfcoppola | OpenFOAM Installation | 20 | November 2, 2007 13:38 |
Wall function problem in Fluent | mefpz | FLUENT | 1 | October 10, 2007 13:43 |
3-D turbulence model with wall function | Henry | Main CFD Forum | 7 | May 19, 2006 10:40 |
