January 15, 2010, 03:41 |
Wall heat transfer coefficient (HTC) problem
Abu Abedrahman
Dear fellows
I have a strange problem with HTC in CFX, I am simulating a simple problem of flow inside duct (isothermal wall), I had defined the tbulk for the expert parameter in the ansys solver, and the results were very good for velocity and temperature profiles except for wall heat transfer coefficient and also wall heat flux, its profile is very good i.e. maximum at entrance then decreases until maintained constant as the profile said but the range of this profile from ZERO to reasonable value, my question is how the wall HTC and heat flux reaches zero and in fact, it did not maintains constant, it varies along the duct from the entrance to exit. best regards |
January 15, 2010, 23:12 |
Rep Power: 143 |
That obviously depends on what the flow is doing. You have not described your flow at all.
Heat Transfer Coefficient | Alberto Schroth | FLUENT | 17 | February 10, 2020 08:40 |
Changing Heat transfer coefficient | Ashish | FLUENT | 4 | February 24, 2009 07:08 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
regarding B.C. of Heat transfer problem | Manoj Padmakarrao Raut | Siemens | 0 | March 17, 2005 00:01 |
conjugate heat transfer problem | Andreas | Siemens | 0 | February 5, 2002 08:00 |
