FSI fluid structure interaction tutorial chapter 23 |
August 4, 2009, 11:22 |
dave
Rep Power: 16 |
Hello all,
I'm trying to follow the chapter 23 of the tutorial that comes with CFX (anys 12), but it won't give me any solutions. The error is that the solver stops. Does anyone have the working workbench files so i can try to compare mine? Thanks. |
August 5, 2009, 14:53 |
New info
dave
Rep Power: 16 |
I'm all done with the configuration, but the solver is saying i have an error. PLease help!!!
This is the info that i get: +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | CFX encountered the error: Read. Fatal error occurred when reque- | | sting Total Mesh Displacement for Boundary 1. | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | cplg_SendCommand failed to send the command: ERROR -- CFX encount- | | ered the error: Read. Fatal error occurred when requesting Total | | Mesh Displacement for Boundary 1. | | | | | | | +--------------------------------------------------------------------+ |
August 5, 2009, 20:50 |
Rep Power: 143 |
When a tutorial does not work 99% of the time it is because you missed something. Go through it again carefully and make sure you don't miss anything. Glenn Horrocks |
August 6, 2009, 18:15 |
i got it to work
#4 | |
dave
Rep Power: 16 |
Thanks Glenn. I got it to work by changing the default mesh (cfx by the automatic one) that was the only change. Anyways, when i try to post process it, it gives me this image http://img329.imageshack.us/img329/1129/ansys.jpg but i believe the wall should be a lot smaller that what is shown on the pic. How can i make the fluid and the wall the same scale? (wall vertical square, fluid small horizantal square, please refer to tutorial 23 wb 12) Thanks. |
February 5, 2010, 01:40 |
can you help me
#5 | |
rose
Rep Power: 16 |
i meet the same problem when solve the FSI |
Fluid Structure Interaction | fw407 | OpenFOAM Running, Solving & CFD | 9 | February 14, 2013 17:25 |
fluid mass in coupled FSI system | Dr. V. Kumar | CFX | 10 | July 16, 2007 10:23 |
Fluid Structure Interaction and OpenFOAM capabilities | paka | OpenFOAM Running, Solving & CFD | 1 | June 6, 2007 13:56 |
Information Regarding Fluid Structure Interaction | Aamir | Main CFD Forum | 6 | April 24, 2002 14:13 |
Fluid Structure Interaction | Delly | Main CFD Forum | 2 | November 26, 2001 12:01 |
