FSI fluid structure interaction tutorial chapter 23
Old   August 4, 2009, 11:22
Default FSI fluid structure interaction tutorial chapter 23
dave
davedave121 is on a distinguished road
Hello all,
I'm trying to follow the chapter 23 of the tutorial that comes with CFX (anys 12), but it won't give me any solutions. The error is that the solver stops. Does anyone have the working workbench files so i can try to compare mine?
Thanks.
davedave121 is offline   Reply With Quote
Old   August 5, 2009, 14:53
Default New info
dave
I'm all done with the configuration, but the solver is saying i have an error. PLease help!!!
This is the info that i get:
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| CFX encountered the error: Read. Fatal error occurred when reque- |
| sting Total Mesh Displacement for Boundary 1. |
| Message: |
| cplg_SendCommand failed to send the command: ERROR -- CFX encount- |
| ered the error: Read. Fatal error occurred when requesting Total |
Old   August 5, 2009, 20:50
When a tutorial does not work 99% of the time it is because you missed something. Go through it again carefully and make sure you don't miss anything.
Old   August 6, 2009, 18:15
Default i got it to work
dave
Originally Posted by ghorrocks View Post
Thanks Glenn. I got it to work by changing the default mesh (cfx by the automatic one) that was the only change. Anyways, when i try to post process it, it gives me this image
http://img329.imageshack.us/img329/1129/ansys.jpg
but i believe the wall should be a lot smaller that what is shown on the pic. How can i make the fluid and the wall the same scale? (wall vertical square, fluid small horizantal square, please refer to tutorial 23 wb 12)
Thanks.
Old   February 5, 2010, 01:40
Default can you help me
rose
justdo is on a distinguished road
Thanks.
you said that you have changed the the default mesh ,can you tell me what you do ahout it? dou you mesh the fliud by the workbench cfx-meshing ?
i meet the same problem when solve the FSI
justdo is offline   Reply With Quote
Fluid Structure Interaction fw407 OpenFOAM Running, Solving & CFD 9 February 14, 2013 17:25
fluid mass in coupled FSI system Dr. V. Kumar CFX 10 July 16, 2007 10:23
Fluid Structure Interaction and OpenFOAM capabilities paka OpenFOAM Running, Solving & CFD 1 June 6, 2007 13:56
Information Regarding Fluid Structure Interaction Aamir Main CFD Forum 6 April 24, 2002 14:13
Fluid Structure Interaction Delly Main CFD Forum 2 November 26, 2001 12:01
