February 8, 2010, 11:08 |
Image formatting
Alisa Selimovic
Hi all,
I need to export my results as a .eps file from CFX Post, but when I do that and open the file in GSView, I see the contour, the legend, the scale, but not the coordinate axis (which is important, as I need to show the direction of blood-flow through a cylinder). I've tried inserting a coordinate frame, but can't seem to make it appear next to the cylinder, instead of within it. Any thoughts? Many thanks, Alisa |
February 8, 2010, 17:08 |
Rep Power: 143 |
Sounds like a bug in CFD-Post. I would report it and get it fixed.
But in the meantime try a different format and convert to eps if you require eps. |
Rotate image 3D | Jorge Munoz | FLUENT | 2 | September 16, 2008 03:57 |
A problem about the image size | alex | Main CFD Forum | 10 | September 14, 2005 14:56 |
output image quality | Ted Crilly | Siemens | 2 | January 17, 2005 06:10 |
Image Print | Matthew Campbell | CFX | 4 | October 10, 2001 05:21 |
