February 10, 2010, 03:36 |
Oxygen mass transfer
Luis Cea
I am trying to model the mixing of oxygen and water in a mixing vessel. I am considering 2 phases and 3 components. The liquid phase is a mixture of water and dissolved oxygen, and the gas phase is pure oxygen. I would like to include the mass transfer from pure oxygen (gas phase) to dissolved oxygen (liquid phase), but cannot find any tutorial which indicates how to do this. The tutorials I have related to mixing vessels do not consider the mass transfer between the gas and liquid phases. Can anyone help with this or give any hint? many thanks, Luis |
February 10, 2010, 05:27 |
Rep Power: 143 |
You will need to contact CFX support for examples of advanced simulations like this.
February 10, 2010, 07:36 |
#3 | |
Idtisak Paopo
February 10, 2010, 10:54 |
Luis Cea
Many thanks for your help.
November 25, 2019, 05:41 |
#5 | |
Antton
Rep Power: 6 |
November 25, 2019, 06:11 |
Gert-Jan
Rep Power: 27 |
You need to model this with 2 phase flow. For O2, you need interphase mass transfer and Henry coefficient.
November 25, 2019, 06:24 |
#7 | |
Antton
Rep Power: 6 |
I want to modelate the oxygen disolved in wáter depending on temperature. I use the Eulerian model and (wáter for primary phase and oxygen for secondary phase) and I actívate species transport. Then I actívate the Henry's law. I dont know if what I am doing is correct… Do you know any idea? What do you want to say with interphase mass transfer? Thank you |
November 25, 2019, 06:31 |
Gert-Jan
Rep Power: 27 |
interphase mass transfer is from one phase to the other. So, from liquid water to gas oxygen. Perfectly fine.
In order to include the dependency from temperature, you need to make the henry coefficient a function of temperature. Do you have pure oxygen? |
November 25, 2019, 06:36 |
#9 | |
Antton
Rep Power: 6 |
Yes, I wnt to know only the change of disolved oxygen in water. I know that the oxygen disolved in water decrease with temperatura so I want to modelate this but only taking into account two phases water and oxygen. So I put water in the primary phase (volumen fraction = 1) and oxygen in the secondary phase (volumen fraction = 0) in the starting point. Then I want to see that the oxygen quantity change because of the temperatura. |
November 25, 2019, 06:44 |
Gert-Jan
Rep Power: 27 |
1) A UDF? Haven't used that in the past 10 years.
You just create an expression for H as a function of temperature and in Pre use that expression where you give in the value for the Henry coefficient. 2) sounds like this is normal water and air, not? So what about nitrogen? You need to include that as well. 3) main challenge will be the initial bubble size. Do you already have any idea about that? |
November 25, 2019, 06:59 |
#11 | |
Antton
Rep Power: 6 |
November 25, 2019, 07:10 |
#12 |
Gert-Jan
Rep Power: 27 |
Are you a newbie? Haven't done any tutorial or similar?
Nevertheless, in Pre, just create an expression (it is in the tree). Something like H=1e3[Pa/K]*T Make sure the units are correct. And then use that expression, where you used the value for the Henry coefficient (click on the expression icon, then use the Right Mouse button, to look up your expression). |
mass transfer, mixing, oxygen |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 02:49 |
free convective and diffusive mass transfer | rajani | FLUENT | 0 | July 27, 2005 09:28 |
Vof, udf and mass transfer panel | Jay | FLUENT | 1 | March 15, 2005 01:29 |
additional variable mass transfer in CFX5.6 | john | CFX | 1 | February 14, 2004 01:30 |
