Swirl Angle Calculation
Like Tree1Likes
  • 1 Post By AliTr
Old   March 8, 2010, 06:57
Default Swirl Angle Calculation
KrishnaMohan.Siddu
krrishcfd is on a distinguished road
Can any one help me in finding the swirl angle in Ansys CFX Post ... before the fluid enters the impeller inlet ...
krrishcfd is offline   Reply With Quote
Old   March 9, 2010, 18:04
Ali Torbaty
AliTr is on a distinguished road
use the following CEL expression to create a variable which represents the Swirl Angles in any plane.
LIBRARY:
CEL:
EXPRESSIONS:
SwAnglePlane = acos((Velocity u *Normal X + Velocity v * Normal Y + Velocity w *Normal Z)/Velocity)
END
END
END
USER SCALAR VARIABLE:SwAngle
Boundary Values = Conservative
Calculate Global Range = Off
Expression = SwAnglePlane
Recipe = Expression
Variable to Copy = Pressure
END
camestha likes this.
AliTr is offline   Reply With Quote
Old   November 4, 2021, 03:34
Munaf
mwmalkawi is on a distinguished road
May i ask what is the reference form where the below formula was taken and are you confident it works and provide the pre-swirl angle because i am facing the same problem and appreciate your help
mwmalkawi is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
spray angle calculation Jay Siemens 1 August 13, 2008 10:34
swirl angle jason tolentino CFX 2 August 6, 2008 13:26
Numerical calculation interFoam never finishes unoder OpenFOAM Running, Solving & CFD 9 October 18, 2005 05:00
Warning 097- AB Siemens 6 November 15, 2004 04:41
