March 31, 2010, 13:54 |
droplet absorption diameter
Rep Power: 17 |
I have a subdomain in which I want to remove particles from the domain. I know that I can use the "Absortion diameter". But now my question: The absorption diameter depends on the gas velocity, is it possible to implement this dependency? I tried to do something like absorption diameter = function of Velocity w, but the following error occurs: "Velocity w is not available for use in this term" Does anyone has an idea? Thanks in advance Claudia |
March 31, 2010, 19:07 |
Rep Power: 143 |
The message is quite clear - you can't make absorption diameter a function of W velocity. Some variables can only be constants or functions of a subset of variables and I think you have found one. If you really need to do this talk to CFX support and they may be able to find a work around for you.
April 1, 2010, 03:15 |
try to create an expression in cfx pre like absorption diameter = f(velocity w), then use this expression in subdomain.
in expression you should use direct difinition, e.g. "massflowave(Velocity W)@inlet*1[s]" it means than your absorption diameter will be equal average velocity w in inlet BC |
April 1, 2010, 08:30 |
Rep Power: 17 |
Thanks, Glenn for your answer. So I have to tell the support about it and I hope they will find a workaround.
April 2, 2010, 07:14 |
Rep Power: 143 |
Yes, that's right. There will be a reason the absorption diameter cannot be set as a function of velocity. If you bypass the check, it may or may not affect your results - so talk to them and try to find out.
absorption, droplet, subdomain |
Display Modes | |
maximum droplet diameter? | antonietta | FLUENT | 1 | February 23, 2006 07:41 |
Miminum diameter of droplet | bk | Siemens | 0 | July 12, 2005 07:54 |
Variable initial droplet diameter | Sam | FLUENT | 0 | June 4, 2005 12:36 |
spray droplet diameter | David | FLUENT | 0 | August 13, 2004 10:06 |
Significance of droplet diameter in multiphase flo | Hbet | FLUENT | 0 | June 14, 2001 10:36 |
