July 23, 2010, 13:26 |
CFX_Batch File
Saima
Rep Power: 16 |
Hi all,
I want to run CFX in batch mode. Could you pls tell me the whole path and sequence. like CFX-Pre...CFX-Solver----CFD-Post I tried like: C:\Users\sanaz\Desktop>"C:\Program Files\ANSYS Inc\v121\CFX\bin\cfx5pre"-batch ROTOR.pre But it is not working. Is there anyone know how to get it ? Thanks in advance!!! Last edited by Saima; July 23, 2010 at 13:57. |
July 24, 2010, 06:44 |
Rep Power: 143 |
Use a command line started in the CFX launcher. Then the path will be correctly defined.
You need a space before -batch. |
July 24, 2010, 10:55 |
Saima
Rep Power: 16 |
Yes tried with cfx5sole and afterthat same path it working now. But my mesh will be chnage every time, I buil script in ICEM CFD. So what wil be the exact path from this mesh file to upto the solution.I wanter to calculate efficiency i introduce ccl file for that. How can i get that eficiency thoruh this path. Kindly let me know. Best Regards, |
August 6, 2010, 13:06 |
Rep Power: 17 |
Unfortunately, I am not familiar with this. However, some of the folks in the following thread may be helpful
http://www.cfd-online.com/Forums/cfx/73105-batch-cfx-12-windows-xp.html Good luck! |
August 7, 2010, 06:48 |
Rep Power: 143 |
CFX support has some example files of linking a CFX solution to ICEM meshing dynamically. Talk to CFX support.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
FoamToVTK and MayaVi | alexandrepereira | OpenFOAM Post-Processing | 57 | August 11, 2008 04:15 |
