confused on messages after solver has terminated
Old   February 21, 2010, 19:29
Default confused on messages after solver has terminated
mactech001 is on a distinguished road
Dear all,
i'm confused on the messages after solver has terminated.
It does indicate that my simulation has reached the desired residual criteria and has stop the solver as shown below.
OUTER LOOP ITERATION = 368 CPU SECONDS = 2.165E+04
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom | 0.97 | 4.5E-06 | 2.9E-04 | 2.9E-02 OK|
| V-Mom | 0.97 | 2.1E-06 | 1.2E-04 | 3.6E-02 OK|
| W-Mom | 0.96 | 9.8E-06 | 8.4E-04 | 1.8E-02 OK|
| P-Mass | 0.98 | 4.4E-07 | 2.4E-05 | 5.0 9.3E-02 OK|
| H-Energy | 0.98 | 7.1E-06 | 7.1E-04 | 1.6E-02 OK|
| T-Energy | 0.98 | 4.2E-07 | 7.8E-06 | 5.8 1.6E-02 OK|
| K-TurbKE | 0.99 | 5.3E-06 | 4.4E-04 | 5.8 2.4E-03 OK|
| E-Diss.K | 0.97 | 1.8E-06 | 1.4E-04 | 12.9 6.9E-06 OK|
CFD Solver finished: Sun Feb 21 23:08:35 2010
CFD Solver wall clock seconds: 2.1693E+04
Execution terminating:
all residual
are below their target criteria.
BUT then, going further down the message page, it claims there's an error.
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Error disconnecting from shared license socket. |
| Writing crash recovery file |
| Message: |
| Stopped in routine RUNF3D |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. |
End of solution stage.
| The results from this run of the ANSYS CFX Solver have been |
| written to E:\Yi CHENG\cylinder with cooling |
| channel\hseAsm11gridRibsL30H3_001.res
How should i treat this result? is this result acceptable please?
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
Old   April 21, 2010, 16:58
JDA
J. D. Aurand
JDA is on a distinguished road
Did you have any monitor points? If you did, did they level off with acceptable variances? I don't know a lot about the error messages, but my first thought is that there was a problem with wrapping up the partitioner or returning the license to the pool. If the monitor points are steady, I would take the results as acceptable, but still be somewhat skeptical (i.e. if another run is vastly different, but converges and everything else looks good, go with those results).
JDA is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
Solver Error messages!! Rajit FLUENT 3 August 27, 2006 15:28
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
