April 1, 2010, 06:09 |
how to study a simple rotating blade?
Francesco
Hello everyone!
I'll tell you now what my problem is. I have to simulate the behavior of a simple rectangular shaped blade of a vertical axis hydraulic turbine. Only a blade to make the comparison with a mathematical model that I have made. I am working in this way. In ICEM I create two domainsne cylindrical (with the) which describes the movement of the rotary blade and the other describing instead the steady inflow and outflow of water. What I need is get the torque that makes the water on the blade. I do not know if I'm proceeding on the right way. I work with a Transient Rotor-stator interface. In your opinion, okay? Looking at the streamlines does not seem to be very correct. What should I do? let me know thanks |
April 1, 2010, 06:23 |
Rep Power: 143 |
What you are doing sounds correct.
What does not look correct about the streamlines? I can guess the reason anyway - draw streamlines using the variable "Velocity in stationary frame". |
ROTATING TURBINE BLADE SIMULATION | Anant | FLUENT | 2 | March 31, 2011 10:57 |
stress analysis of a rotating beam(wind blade) | Cheyannne | ANSYS | 0 | October 19, 2009 17:06 |
Setting up a point monitor rotating with the blade | Hamidur | CFX | 1 | September 13, 2008 17:00 |
2D Compressor cascade study using DFLVR blade | kiran | FLUENT | 1 | May 24, 2007 15:01 |
Flow study through Turbine Blade passage | Subrata | FLUENT | 1 | May 4, 2007 11:28 |
