April 5, 2010, 09:16 |
quality of results (conversion)
Rep Power: 16 |
How can i judge after a solver run if the results are allready converted
using the .lsf and the .out file??? what kind of creterias should be present so i can say that the result is good enough? thank you! |
April 5, 2010, 19:05 |
Rep Power: 143 |
Read the documentation about convergence tolerances.
But you cannot tell from a single simulation whether your results are good enough. You need to do a series of simulations sweeping all major tunable parameters to determine the sensitivities. |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
Different Results from Fluent 5.5 and Fluent 6.0 | Rajeev Kumar Singh | FLUENT | 6 | December 19, 2010 11:33 |
[ICEM] Hex refinement negative quality afterwards | Anorky | ANSYS Meshing & Geometry | 8 | March 22, 2010 03:25 |
validation of CFD results | andy | FLUENT | 0 | June 13, 2007 13:55 |
Different types of Mesh quality | hagupta | CFX | 1 | June 30, 2006 07:42 |
