April 8, 2010, 11:24 |
Multiphase simulation
Willian
Rep Power: 16 |
Iīm learning using Ansys CFX 12.0 and a have a problem with multiphase simulation. My geometry is a kind of cup with an initial level of water and Iīd like simulate the flow inside it when the wall rotates at 2 rad/s, considering a steady state analysis. On CFX-Pre, I started defining in my default domain two fluids, air and water, but I didnīt know how to set this initial level of water and separate it from the air, like a two phase system. Iīve already considered no slip wall, laminal flow, buoyancy and surface tension but my results for volume fraction on CFD-Post are not what I expect, like a paraboloid shape. I couldnīt find the same situation on tutorials. Can someone help me? Thanks, Willian |
April 8, 2010, 11:53 |
Ciro Cannavacciuolo
Rep Power: 17 |
Hi, maybe I can help you but I think that the simulation is too complicated for one person that now is learning code.
So, could you send me an image of your domain? Is it your first multiphase simulation? Regards |
April 8, 2010, 17:13 |
Freeman Adane
Rep Power: 15 |
hi mach000,
were you able to fix that? I'm having similar problems..... |
April 8, 2010, 17:20 |
Willian
Rep Power: 16 |
Yes, itīs my first multiphase simulation and I canīt find anywhere an example for a similar simulation in Ansys CFX. As a first aproximation, I created a simple cilynder using ICEM tools and allowed an auto sizing meshing. My parameters are basically a rotating wall, 2 rad/s, and top surface open to atmosphere and my initial condition is that 50% of cilynder volume is full of water. I think my problem is setting this initial level of water and make sure that there is a two phase situation (Air, Water). Is there any difference in results between defining a new material as a mixture and selecting two materials in domain settings? Thanks a lot for your help, Willian Ps.: ICEM Mesh: http://img641.imageshack.us/i/cilindro.png/ Last edited by 100tinela; April 8, 2010 at 17:22. Reason: Icem mesh: http://img697.imageshack.us/i/cilindroy.jpg |
April 8, 2010, 19:17 |
Rep Power: 143 |
It is very hard to run free surface simulations steady state. You will probably have to run the simulation as a transient and wait for the surface to settle out.
April 9, 2010, 04:34 |
#6 | |
Ciro Cannavacciuolo
Rep Power: 17 |
Then, why don't you try to create an hexa elements mesh? Finally, in order to simulate a multiphase simulation you need to define some expression such as Stevin Law and the initial quote of the freesurface. You will find theese expressions in some tutorials. Let me know |
April 9, 2010, 07:41 |
#7 | |
Willian
Rep Power: 16 |
Thanks for your help, Willian |
April 9, 2010, 08:33 |
#8 | |||
Rep Power: 143 |
Don't use the surface tension model unless you need it. It makes convergence even harder and mesh quality requirements even stricter. And as I previously said, you have little hope in getting this to work steady state. You will have to run transient and march it out until the waves die down. |
April 15, 2010, 03:09 |
#9 | |
Ali Torbaty
Rep Power: 16 |
Display Modes | |
multiphase simulation crash | austin | FLUENT | 2 | February 25, 2009 09:38 |
Single phase result file for multiphase simulation | Kushagra | CFX | 2 | July 8, 2008 22:14 |
Multiphase radiation in Ansys 10 problem | Luk | CFX | 2 | June 5, 2008 12:31 |
LES for multiphase simulation | Kushagra | CFX | 0 | April 24, 2008 20:51 |
multiphase simulation... 2D flow through an elbow | Tim | CFX | 10 | April 3, 2008 19:13 |
