May 10, 2010, 17:19 |
Conjugate Heat Transfer & Radiation
Rep Power: 16 |
I want to model radiation of a solid body in a cht-problem. So i have to use Monte Carlo Model. What i did is setting the transfer mode for the solid domain to participating media, the spectral model to gray and the material properties refractive index, absorption coefficient and scattering coefficient. In the Domain Interface Boundary Details Tab, Thermal Radiation Option is set to Opaque, Emissivity is 0.6, Diffuse Fraction is close to Zero.
As result, i get values for Radiation Intensity, but the temperature of the solid (a 900K steel plate in 300K air domain) does not change in comparison to a calculation without radiation... What could be wrong? What steps are missing? Thanks and regards! |
May 10, 2010, 18:57 |
#2 | |
Rep Power: 143 |
The Monte Carlo model is tricky to get working properly so it does not surprise me you are having problems with it. Discrete Transfer is much easier. |
May 11, 2010, 14:55 |
Rep Power: 16 |
Yes, You are right! I accidently set up the radiation model for the solid domain instead of the fluid domain. Now, both models, the descrete transfer and monte carlo, are working and give nearly same results for the temperature field.
Display Modes | |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Conjugate heat transfer problem | hvem10 | FLUENT | 2 | October 29, 2009 17:31 |
Conjugate heat transfer and radiation modeling questions | shankara.2 | FLUENT | 0 | April 21, 2009 15:55 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Radiation Heat Transfer | The IFRF Heat Transfer Team | Main CFD Forum | 0 | January 31, 2000 14:02 |
