text file to modify
Old   April 12, 2010, 06:58
Default text file to modify
Domenico
c120613 is on a distinguished road
Dear all,
I'd like to know if after the setting of the parameters in CFX-PRE, it is possible to generate a .txt file which contain all of the parameters of CFX-PRE. In fact the problem is that even if I want to do a small modification on the parameters of CFX-PRE I waste a lot of time by opening again the CFX-PRE. Then I suppose that a txt file will be much more easier to open and modify.
Does somebody know how can I create it ?
Kind regards
Domenico
c120613 is offline   Reply With Quote
Old   April 12, 2010, 09:34
puga is on a distinguished road
I think what you're talking about it exporting the CCL.
Under File--> Export CCL, you can output a file with everything from the current workspace. This is a text file (that you can edit). If you want to reload all of this, simply open CFX and go to File-->Import CCL.
puga is offline   Reply With Quote
Old   April 13, 2010, 20:08
Ali Torbaty
AliTr is on a distinguished road
There is a solution, but it is good when you need to do several runs and need to change some parameters in one base model for each run.
You have to make a CCL file (e.g. myccl.ccl) contains new parameters to update an existing .def file, run the below command from CFX command line:
cfx5solve -def xxx.def -ccl myccl.CCL
this command will update .def file and start solver to run the model.
however I suggest this method whith several runs in batch when it is needed to change some parameters for each run.
ps. I assumed you are familiar with CCL file structure.
AliTr is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 14:30
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
