April 20, 2010, 02:26 |
Multiphase convergence problem
I'm running a liquid-gas multiphase problem with liquid as the continuous phase. I need to anlayse over a range of properties (constant) of the liquid phase. With a low viscosity (10 centipoise) i have no problems. The problem begins when i increase the viscosity to 500 cP and 1000 cP. The momentum imbalances fluctuate a lot (10-20%). I've even tried running the case as laminar (considering the higher viscosity) with the same problem. Any suggestions. Luke |
April 20, 2010, 07:38 |
Rep Power: 143 |
Hopefully there is a physical explanation for it - but I can't think of one. You would have to give more details about what you are modelling.
Does some transition happen as the viscosity goes up? Maybe the bubble go from spherical cap to spherical regimes and you are using an inappropriate drag model which gives wrong drag numbers and leads to instability. |
April 21, 2010, 00:25 |
Thanks Glen,
But i tried modeling the flow as single phase (laminar, with 1000 Cp viscosity) and arrived at the same fluctuating imbalances. This is as simple as you can get. Constant property fluid, laminar flow .. i dont get why it's so tough to converge. The inlet velocity is 9.84 m/s and domain pressure 10 bar. |
April 21, 2010, 18:54 |
Rep Power: 143 |
I repeat - does some transition happen? Maybe you go from the spherical cap regime to spherical and your drag model is not appropriate any more.
Nothing is "simple" when you are talking multiphase flow. |
high viscosity, multiphase flow |
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 10:47 |
Continuity eq convergence problem | carno | FLUENT | 4 | February 8, 2008 04:04 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 00:24 |
convergence problem | Trushar | Phoenics | 5 | August 27, 2002 23:40 |
Convergence problem when ustructured mesh is used. | SangJin Ryu | Siemens | 3 | October 5, 2000 20:26 |
