May 6, 2010, 15:28 |
Boundary priority
FM
Hi
I'm simulating a simple heat transfer problem: a flat square plate with prescibred Temperature in two oposite faces and adiabatic at the others faces. My doubt is: wich one of these boundaries (Prescribed temperature or Adiabatic) is being used at the interfaces nodes (the nodes that belong to two different boundaries faces)? How can I see it? Can I define a stronger boundary so that I know wich one I'm using? Thanks |
May 6, 2010, 22:20 |
#2 | |
Rep Power: 143 |
For the control volume which includes both the adiabatic boundary and the fixed temeprature boundary, the adiabatic boundary will apply to that face and the prescribed temperature will apply to that face. The wall boundaries are not evaluated at the nodes to avoid the precise issue you discuss. Instead the wall boundaries are evaluated at the element faces and therefore the state of all boundaries is clear. |
May 11, 2010, 18:42 |
#3 | |
FM
- Incompressible, laminar (Re = 100) flow into a pipe - Prescribed constant velocity at the inlet face (v = 5 cm/s) - Prescribed pressure at the outlet face (P = 1 atm) - No slip wall The first node, at the interface of the inlet and the wall boundary, has the inlet velocity ( v = 5 cm/s ), but the next node in the direction of the flow (a node over the wall) has velocity near zero ( v ~ 10^-14 cm/s): both hybrid values. This is a situation where the inlet boundary is stonger than the wall boundary. The high velocity at the inlet (compared to the wall velocities) os causing a peak of pressure at the wall near the inlet, i.e., a strong pressure drop at wall in the beginning of the pipe. Isn't this a case where the boundary is store at the node and not the element faces? ps.: There are some images that can help understand. They're at the attachments. Thanks |
May 11, 2010, 19:36 |
Rep Power: 143 |
Again you are incorrect. Read the section on discretisation and solution theory - variables are stored at the nodes and control volumes are built around the nodes. The fluxes for the control volumes are evaluated at the control volume faces (at the integration points), and a boundary can form a control volume face. This means that boundaries are evaluated at the control volume faces, not the nodes. This means there is no strange behaviour at the intersection of two boundary conditions like you suggest.
May 11, 2010, 20:10 |
FM
What could be the pressure peak problem at the entrance?
May 12, 2010, 09:41 |
Rep Power: 143 |
Isn't that caused by the assumption of constant velocity over the inlet boundary? It would be eliminated by applying an inlet boundary with something closer to a boundary layer profile.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 22:25 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 02:54 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 09:59 |
