BC Profile with Turbulent Intensity
Old   May 13, 2010, 04:36
Default BC Profile with Turbulent Intensity
blackbody is on a distinguished road
hi everybody!
can i use turbulent intensity (%) as a profile boundary condition?
when i look at the "standard variable names" in CFX helper i only
see that i can specify k (turbulence kinetic energy) as a profile bc parameter.
if i use k in the profile BC, than CFX ask me for epsilon (turbulent dissipation rate). i dont have epsilon though....
any suggestion?
thank you very much!
blackbody is offline   Reply With Quote
Old   May 13, 2010, 08:10
Turbulence intensity % just defines the turbulence intensity (k) as a function of flow velocity. It does not define the second variable required to specify the turbulence inlet condition. You will need to specify an epsilon, turbulence length scale, turbulence viscosity scale or some other independent turbulence parameter to define the second turbulence variable.
How to calculate Turbulent Intensity? prem FLUENT 10 September 29, 2018 10:46
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 11:36
Turbulent intensity swe704 Main CFD Forum 0 November 13, 2009 04:42
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
Turbulent Intensity good or bad for a jet Christian Main CFD Forum 0 November 19, 2003 06:47
