June 7, 2010, 05:47 |
Turbulent Schmidt Number default value
Forrest
Rep Power: 16 |
Hi all,
Recently I am revisiting some of the cavity natural convection cases I did before using CFX version 12 (previously the work was done by version 5.7 if i remember correctly). If I turn on the buoyancy 'production and dissipation', the turbulent schmidt number is now 2.0 by default, and I know it was 0.9 before. Does anyone know what are the underlying reasons to change this default value? What kind of difference we would expect with these two values for a closed cavity natural convection case? The case I am looking at right now is a well defined case, 2D, vertical walls have a temperature difference, the horizontal walls are adiabatic. thank you for your comments Regards, Forrest |
June 7, 2010, 06:07 |
Rep Power: 143 |
I have no idea why the turb schmidt number changed. If you don't like it then change it back! If you go through the release notes of the versions between 5.7 and 12 you should find a reason for the change. Alternately contact CFX support.
And by the way, there are not many turbulent natural convection cases which are 2D. They almost always develop 3D transient flow features if the Rayliegh number is high enough to generate turbulence. |
June 7, 2010, 06:29 |
Forrest
Rep Power: 16 |
Dear Glenn,
Thanks for your quick reply. I am not quite sure when this was changed, since versions 10, 11, or 12, I will have a look the release notes if I still could find them for these versions. I agree with you about the natural convection cases, most of the time they do not behave exactly as expected numerically. There were some experimental investigations in the past, researchers reported 2D characteristics of their 3D experiments, especially in the centre of their test cavity. Regards, Forrest |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Low Reynolds number k-E Turbulent Model | Sohail | FLUENT | 19 | July 16, 2020 14:08 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
how to change turbulent schmilt number | Andy | CFX | 1 | April 8, 2006 05:35 |
