cylinder and piston
Old   June 10, 2010, 07:16
Default cylinder and piston
mohsen
m.shams is on a distinguished road
Hi every one
Excuse me if my English is not good.
I am beginner in cfx. i simulated cylinder and piston. figure below indicates the geometry and meshes. For simulating piston I used mesh deformation feature and analyze type is transient. but when solving error below occured.
If possible, please guide me.
Thanks a lot
Error:
Fluid Flow_003 has terminated with errors.
Run concluded at: Wed Nov 10 15:25:42 2010
Results are in
C:\piston- 1 domain\piston_files\dp0\CFX\CFX\Fluid Flow_003.res
the *.out file of solution attached to this post
m.shams is offline   Reply With Quote
Old   June 10, 2010, 08:13
You have defined the piston motion as a constant - 2[m]. This means the mesh will jump to this position in the first time step and stop there. This is wrong, you have to write the displacement as a function of time, maybe a sin() function or something so the piston can move gradually as a function of time from the starting location to the finish location.
Old   June 10, 2010, 15:21
mohsen
my problem solved with your guid
thanks a lot for your reply.
No pressure increase with compressing piston Erik Siemens 0 December 23, 2008 04:51
simulate a 4-stroke piston cylinder san CFX 3 October 11, 2006 13:28
help to simulate 4-stroke piston cylinder san Siemens 2 September 29, 2006 13:37
CFD Work on 4-stroke piston cylinder san FLUENT 0 September 20, 2006 13:27
Simulation of hydraulic piston cylinder assembly Vijay FLUENT 0 January 13, 2006 11:39
