July 22, 2010, 02:09 |
mass flow unit change
jaikrishna
Rep Power: 17 |
I want to view massflow rate in the unit of kg/millisec in CFD-post. how can i do it? and
In pre i've given mass flow rate in kg/sec and i do a transient simulation for less than 1 second. now i want to know the total mass flow for the particular time period. |
July 22, 2010, 03:49 |
Just Units...
#2 | |
Matthias Voß
Rep Power: 20 |
Rate is rate, nomatter how long you calculate it. Just divide by 1000 and you end up with you kg/millisec. neewbie |
July 22, 2010, 04:04 |
Re
jaikrishna
Rep Power: 17 |
how can i change the unit showing in post?
even through custom mode i can change to kg/sec, kg/hr and kg/min but i can't able to change into kg/millisec.. |
July 22, 2010, 04:22 |
Matthias Voß
Rep Power: 20 |
hi,
1.create an expression like mymf=Fluid.Mass Flow 2.create an Variable mymf which is the expression mymf AND here comes the trick 3.make a new variable which is a copy of mymf(variable) let´s say MassFlow then rightclick over MassFlow --> edit in Command Editor and add a field like kg ms^-1 at the field User Unit. I guess you could just do the second step (Frozen Copy of a Variable) since you probably already have something like Fluid.Mass Flow neewbie |
July 22, 2010, 07:16 |
Re
jaikrishna
Rep Power: 17 |
Pls show me the screenshot of 3rd step if possible because i've not seen any user unit line there...
Pls ref the attached pic. |
July 22, 2010, 07:25 |
Matthias Voß
Rep Power: 20 |
i don´t know what your expression mf is like. anyways.
but i actually discovered that cfx will change the units back to kg/s, so you will have to change to not showing the units in the legend and than insert a textbox telling the corresponding unit (e.g. [kg/ms]). for my way was working,... so im not sure why it isn´t the case for you. neewbie |
Mass Flow Rate Error | jallison | FLUENT | 1 | May 16, 2011 16:22 |
Porous Medium & Mass Flow Rate | NewMY | FLUENT | 4 | November 26, 2009 02:26 |
different mass flow rates | michael | FLUENT | 4 | February 21, 2005 03:48 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 04:18 |
Determine mass flow rate along flow path | Atit Koonsrisuk | CFX | 2 | October 5, 2003 04:47 |
