February 19, 2010, 04:23 |
Saving residual/monitor point plots
Stuart
Rep Power: 25 |
Is it possible (and if so how) to save the various plots that are shown in CFX-Solver? I cannot find anything in the help guides. Thanks. |
February 19, 2010, 08:30 |
prout
Rep Power: 16 |
They are stored in the .res file
February 20, 2010, 05:10 |
Rep Power: 143 |
What do you mean by save? If you mean export the data - then you right click on the graph and export it. If you mean save the layout of the graph - then you save a layout file (I think that is what it is called). If you mean the data contained in the graph - that is contained in the res file as zboud says.
February 20, 2010, 05:45 |
Stuart
Rep Power: 25 |
I was meaning saving the plots as images (i.e. jpg) so that I can put them in reports.
February 21, 2010, 17:06 |
Rep Power: 143 |
Have you tried a screen dump? Press control-print screen and paste it into a graphics application (Paint if you have nothing better)
August 5, 2010, 04:10 |
CFX -> Text CSV -> Gnuplot -> PNG
Rishi .
Rep Power: 17 |
This is out of date for the current thread, anyways somebody might find it still interesting.
1. Generate comma seperated text files from results or current directory of CFX result. The example below is for output of USER POINT. Other cfx5mondata -res RESULT.res -varrule "CATEGORY = USER POINT" > mistfile.txt Other options for result file/dir are -def <file> -res <file> -dir <directory> Options for varialbes are -varlist <variable list> -varlist "RESIDUAL,RMS,U-Mom;RESIDUAL,RMS,V-Mom" Once this data is in a CSV file, gnuplot can be used to visualize the data in this CSV file. create a example.plt file like the one below and use GNUPLOT. set datafile separator "," set terminal png nocrop enhanced size 1200,1000 set output "test.png" plot 'mistfile' using 1:2 title "In1", 'mist' using 1:3 title "In2", 'mist' using 1:4 title "Out" |
How to read vorticity plots | Quarkz | Main CFD Forum | 2 | November 12, 2007 19:20 |
Smooth plots of external data | samu | Siemens | 2 | May 21, 2006 13:08 |
Kiva, Plots of mesh after generation | Sanaz | Main CFD Forum | 3 | March 19, 2006 11:27 |
drawing of contour plots | chinthakindi | Main CFD Forum | 1 | April 27, 2004 04:33 |
Saving plots. | J. Keays | CFX | 3 | August 29, 2001 02:51 |
