July 15, 2010, 16:30 |
"Velocity.curl" in CFX-post
^_^
Rep Power: 17 |
I am using Ansys 12. in CFX-post, there are variables "Velocity.curl", "Velocity.curl X", "Velocity.curl Y", and "Velocity.curl Z".
I thought "Velocity.curl" is a vector. But when I used "ave(Velocity.curl)@blade", it gave me a scalar, and this scalar is not the square root of "Velocity.curl X", "Velocity.curl Y", and "Velocity.curl Z". What is "Velocity.curl" then? Thanks ! |
July 15, 2010, 19:04 |
Rep Power: 143 |
It is the magnitude of the Velocity.curl vector, so is just a scalar.
Also the average of the magnitude of a vector field does not equal the sqrt(sum of squares of vector field components). Do the maths and you will find they are not equal. For instance, (sum(x))^2 does not equal sum(x^2) |
September 13, 2010, 19:44 |
#3 | |
^_^
Rep Power: 17 |
Sorry. What is the magnitude of a vector field?
Here is what I got: Velocity.Curl = 9102; Velocity.Curl X= 132.4; Velocity.Curl Y= 1289; Verlocity.Curl Z= -9.074; I still could not figure out how 9102 is related to other numbers... Quote:
September 14, 2010, 03:22 |
Rep Power: 143 |
The magnitude is simply sqrt(X^2+Y^2+Z^2). This is basic vector maths, you won't get very far in CFD if you don't know things like that (sorry to be brutally honest).
Velocity.Curl is a vector field, made up of three scalar components Velocity.Curl X, Y and Z. At any point in the field the sqrt(X^2+Y^2+Z^2) will hold, but as I said previously this does not work if you average the variables over the field and expect sqrt(X^2+Y^2+Z^2) to hold on the averaged values. |
September 14, 2010, 12:10 |
#5 | |
^_^
Rep Power: 17 |
Thank you, ghorrocks.
I got what you mean. The values I got is the average value over the field instead of value for a signal point. Quote:
CFX post legend modification | mactech001 | CFX | 3 | December 25, 2011 22:12 |
Variable for Number of Mesh Elements CFX Post | Matt | CFX | 0 | August 14, 2008 17:05 |
Chart Generation in CFX Post | Vadim Baines-Jones | CFX | 2 | August 28, 2007 09:14 |
boudary layer distance in CFX POST | toovac | CFX | 2 | February 15, 2007 08:34 |
Tecplot for CFX post processing | pantangi goud | CFX | 2 | August 24, 2005 16:42 |
