October 5, 2010, 04:52 |
CFL-Number
Rep Power: 17 |
I know CFX is an implicit solver nevertheless i wanted to know which best practice range for CFL number does exist for multiphase flows.
thanks Julienne |
October 5, 2010, 09:27 |
Rep Power: 21 |
There's no recommended range. For example, as you refine your mesh your CFL number would change, but in general you wouldn't need to adjust your timestep.
October 8, 2010, 13:35 |
Rep Power: 17 |
From theory we know, that an implicit solution is stable independent from the time step. I guess does not include source terms from reaction or multiphase. For that reason in that applications you may require smaller time steps.
October 9, 2010, 05:54 |
Rep Power: 143 |
To expand on the previous comments: Explicit solvers have a stability limit at a Courant number of 1. You simply can't go faster than that. But CFX is an implicit solver so this restriction does not apply (but a very common mistake is to forget this and run CFX with a Courant number <1).
So the timestep required for CFX should be determined with a sensitivity study on a case by case basis. The allowable timestep is often much bigger than 1.0, but exactly how big is OK depends on the simulation. |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
