October 14, 2010, 01:18 |
variable composition mixture
ranjith
Rep Power: 16 |
I am simulating mixing of two fluids of different viscosity and different density. For this I have defined a variable composition mixture. The domain is initially filled with fluid A( by defining mass fraction of A as 1 in the mixture initially). The fluid entering the domain is entirely composed of fluid B( by defining mass fraction of B as 1 at the inlet). Bouyancy is switched on to capture the hydrostatic effects. A transient simulation was done with total time equal to the time taken to travese the domain(at a fixed flow rate) The problem is that there is no flow at all. Instead a small portion of the fluid at the outlet comes in. I dont know why this happens. Would greatly appreciate any help Ranjith |
October 14, 2010, 21:10 |
Michael P. Owen
Rep Power: 17 |
Did you initialize the hydrostatic pressure?
October 14, 2010, 23:30 |
ranjith
Rep Power: 16 |
No, where can I do it
October 15, 2010, 09:50 |
Michael P. Owen
Rep Power: 17 |
Domain Initialization. Read the tutorials on free surface flows to see how to initialize a hydrostatic pressure.
variable composition mixture properties | Neser25 | CFX | 6 | August 17, 2020 14:19 |
Variable Composition Mixture vs. Fluid Pair | Abby | CFX | 0 | February 18, 2009 11:00 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Variable composition mixture .vs. reacting mixture | Ting Wen | CFX | 0 | January 7, 2008 06:04 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
