November 14, 2010, 15:56 |
A negative ELEMENT volume
Pavelistyj
Rep Power: 15 |
Hello all,
I'm doing an Transient FSI using CFX. When I start the CFX solver I get A NEGATIVE ELEMENT VOLUME error. I'm using a moving mesh, so I think this is the source of the problem. How can prevent it? Thanks, Pavelko |
November 14, 2010, 16:46 |
Rep Power: 143 |
This is a common problem in FSI simulation. It simply means you have moved the mesh far enough to cause some elements to turn inside out and that means the solver will fail. You have to improve the mesh motion specification to bettyer handle the motion, include remeshing or change the model to use other approaches (for instance GGI interfaces).
negative element volume (CFX-10.0) | CFDworker | CFX | 8 | September 27, 2011 18:16 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
