Time-dependent BC's
Old   December 25, 2010, 12:59
Default Time-dependent BC's
doodek is on a distinguished road
I have a small problem with time dependent boundary conditions.
I would like to solve rotor-stator problem (periodic subsection). How to obtain change of rotational speed with time? For example: for 0-10 second rotational speed 1000 rpm, for 10-20 s rotational speed 20 000 rpm. I have the same problem with pressure in inlet boundary condition. How to simulate sudden pressure jump in inlet (for example after 5. second)?
I would be grateful for all suggestions.
Regards,
doodek
doodek is offline   Reply With Quote
Old   December 25, 2010, 17:09
Use a CEL expression to define the rotational speed or pressure as functions of time. You can either use a 1D interpolation function or CEL functions. V12 or earlier you have to use the step() function, V13 you can use if/then statements.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
timestep for time dependent RANS fab Main CFD Forum 4 May 2, 2005 01:29
time dependent curve faiz rauf FLUENT 0 August 31, 2004 13:02
Time Dependent Solutions. rakib FLUENT 2 June 28, 2000 07:39
