January 19, 2011, 22:49 |
Writting In Expression
HMR
Rep Power: 15 |
I am unable to write following expression (Pressure-51957[Pa]/(0.5*996.2[kgm^-3]*16.91[ms^-1]^2 I am getting the following error "ERROR Syntax error detected in the expression assigned to 'PCoef'. Successfully read 30 characters: (Pressure-51957[Pa]/(0.5*996.2 then error detected at: [kgm^-3]*16.91[ms^-1]^2 Details - Unrecognised or invalid units." If I write a expression having same unit then its ok but like above type of expression I can't create in CFX V12.1. Please help me. |
January 20, 2011, 02:29 |
Lance
Rep Power: 22 |
Try [kg m^-3] and [m s^-1] instead of [kgm^-3] and [ms^-1]
and maybe also (16.91[m s^-1])^2 instead of 16.91[ms^-1]^2 |
January 20, 2011, 02:49 |
Rep Power: 17 |
The expression is to be entered as:
(Pressure-51997[Pa])/(0.5*996.2[kg<space>m^-3]*(16.91^2)[m<space>s^-1]).
Best regards, Santhosh. |
January 20, 2011, 03:02 |
HMR
Rep Power: 15 |
Its working, thanks you guys
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 02:11 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
Creating, loop or iteration using expression edito | Jan | CFX | 3 | July 28, 2003 11:01 |
