Gradient of a variable in CFX
Old   February 9, 2011, 09:31
Default Gradient of a variable in CFX
Shahid Parvez
shahpar73 is on a distinguished road
Hi
Is it possible in CFX to calculate the Gradient of "My defined Variable" with respect to temperature? i,e
My defined Variable.Gradient T
It is not working for me saying "T" is not recognized. When I replace "T" with "X" then it is OK.
shahpar73 is offline   Reply With Quote
Old   February 9, 2011, 18:36
You cannot do it directly. You can only do gradients like that WRT space. But dV/dT=dV/dX * 1/(dT/dX) so you should be able to calculate it from the spatial gradients of your variable and temperature.
Old   February 9, 2011, 23:12
Shahid Parvez
Thanks Glenn. Your response always helped me.
I tried your suggestion and got the following error message. Any comments Please...
| PROBLEM ENCOUNTERED WHEN EXECUTING CFX EXPRESSION LANGUAGE |
| The CFX expression language was evaluating: |
| Additional Variable Value |
| The problem was: |
| DIVIDE-BY-ZERO |
| FURTHER INFORMATION |
| The problem was encountered in executing the expression for: |
| GradSurfTension |
| The complete expression is: |
| Surface Tension.Gradient X*(1/T.Gradient X) |
| The error occurs on sub-expression: |
| 1/T.Gradient X
Old   February 10, 2011, 01:56
Lance
Lance is on a distinguished road
Your expression T.Gradient X is zero... due to uniform initial conditions maybe?
Lance is offline   Reply With Quote
Old   February 10, 2011, 04:15
Um, why are you doing this? If you have a surface tension set as a function of temperature you already know the gradient of the surface tension WRT to temperature, so why get CFX to calculate it?
Old   February 10, 2011, 05:07
Shahid Parvez
Hi Glenn,
If you look at the expression, Surface Tension is NOT set as a gradient of Temperature rather set as "X" and I want to calculate the Surface Tension as a Gradient of Temperature in a way as you mentioned in your previous reply.
Old   February 10, 2011, 05:59
OK, no problem.
Old   February 10, 2011, 08:29
Shahid Parvez
Just noticed in Cfx Post that "T.Gradient X" is zero at t=0, and then nonzero. Any solution then? How to skip t=0 in transient analysis?
Old   February 10, 2011, 15:36
Edmund Singer P.E.
singer1812 is on a distinguished road
Perhaps add a non zero value to the T.Gradient.X term and a step function. Like
(T.Gradient X+0.0001 [K m^-1]*step(.00001-t*1[s^-1])
for a quick and dirty solution. Make sure you change .00001 to something that suits your time step.
singer1812 is offline   Reply With Quote
Old   February 10, 2011, 17:00
Back to my previous post.... I am still puzzled by what you are trying to do. Surface tension is usually constant (so dS/dT=0 where S is surface tension and T is temperature) so if it is not constant you must have set it to be a function of something. So why not simply work out the derivative of that function WRT temperature?
Can you explain what function you have set surface tension to?
Old   February 10, 2011, 22:03
Shahid Parvez
I want to calculate the Marangoni Force such that MF=dS/dT*dT/dX [N m^-2] (where S is in N/m) and apply it as a BC.
So in my case S is not constant but a function of temperature and temperature is a function of "X". In CFX, as you mentioned earlier, dS/dT can not be calculated directly and that is why all this stuff come.
Old   February 10, 2011, 22:22
Shahid Parvez
Problem solved. Thanks to all who replied to this post.
I followed Singer's instructions by adding a small value of 1e-10 [K m^-1] to T.Gradient X and it worked.
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Boundary Condition for variable Gradient wilko OpenFOAM Running, Solving & CFD 1 March 13, 2009 12:30
hi how to set entironment variable in CFX pre romance CFX 0 December 23, 2007 07:11
User Defined Variable in CFX PRE Hamidur Rahman CFX 2 September 21, 2007 14:18
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
