Flow around a cylinder with initial disturbance
Old   November 28, 2015, 09:11
Default Flow around a cylinder with initial disturbance
Fryderyk
freddiew93 is on a distinguished road
Hi
I am studying the effects of turbulence modelling on the near-wake flow past a circular cylinder. According to literature on the subject an initial disturbance needs to be included in the model in order to break the symmetry of the flow and hence trigger the generation of vortex shedding. A standard practice is to rotate the cylinder a few turns, say 4, clockwise over N time steps at the beginning of the simulation.
My question is how would one implement that in CFX? I don't have that much experience using the software so I would appreciate some advice, preferably in layman's terms.
Cheers
freddiew93 is offline   Reply With Quote
Old   November 28, 2015, 12:38
Fryderyk
Would setting the following expressions work?
nturns = 4;
nTS = 200;
vel_rot = (2*pi*nturns)/nTS *(1-step(ctstep - nTS));
and setting the cyilinder as a rotating wall with velocity vel_rot around vertical axis. Would that result in cylinder turning nturns times during the first nTS timesteps and then remaining stationary for the remainder of the simulation?
I'm having difficulties understanding differences between current and accumulated time steps.
I'd also like this expression to work universally for steady and transient simulations?
Any suggestions welcomed
Thanks
Old   November 28, 2015, 19:33
First of all - it is unlikely you need to rotate the cylinder to induce the asymmetric flow. I have never had to do it before for cylinder flows. There is enough asymmetry in the mesh and noise in the numerical algorithm that if the flow is unstable it will start all by itself.
Ignoring that and assuming you want to rotate the cylinder anyway:
I think your equation is wrong. Something like:
rotational_velocity = if(ctstep<200,10[rpm],0[rpm])
looks better (and simpler) to me. I am just using 10rpm rather than 4 turns, it is a bit arbitrary anyway.
settlingFoam unstable? bendel_boy OpenFOAM Running, Solving & CFD 38 July 8, 2016 05:07
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
