cfd post - default setting override
Old   February 23, 2011, 22:30
Default cfd post - default setting override
turbotel is on a distinguished road
by default numbers are in scientific format and number of digit is 4 ...etc.
every time i need to change the default.
how can i change the defaults in cfd-post?
turbotel is offline   Reply With Quote
Old   February 24, 2011, 13:31
joey2007 is on a distinguished road
Do not know if its the most elegant way: record a session file where the legend is adjusted. Run this session every time. In order to start faster there is environment variable to locate the macro. If you set you can the environment variable you can start like a build-in-macro.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
post graduate opportunity in CFD application in Military teguhtf Main CFD Forum 1 February 27, 2024 06:29
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
CFD post vector plot problem bharath CFX 3 February 8, 2011 17:16
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 08:19
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 08:45
