Setting materials to solids
Old   February 25, 2011, 10:00
Default Setting materials to solids
Neusier is on a distinguished road
Hi there,
I'm new in this forum, so first: hello everyone.
I have a little and I think that easy to solve problem. It's my first time using CFX and I am lost.
The question that I have its simple. How do I set materials to the CAD models? I mean, I am designing a duct for heating, a simple one: just a prismatic duct with an inlet and outlet.
If I suppose that the CAD model its the whole fluid I get the solve without many problems, but the point is that I want to assign a material to the solid duct so the heat energy lost happens.
I have done all the Ansys examples, but I dont get the real answer. What do I have to do? It's just doing two CAD models: one as the duct and the other as the fluid, and then creating two domains and setting the materials? Its possible to do it with just a solid? Giving it a thickness?
Im sorry if my explanation its not very clear, but my English isn't enough to explain like I'd want.
Neusier is offline   Reply With Quote
Old   February 25, 2011, 13:46
joey2007 is on a distinguished road
You have to mesh both domains and set the type of one as solid and of the other as fluid. There is one tutorial showing the setup (not the meshing).
For interfaces you can set a thin wall with a thickness.
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
Old   February 25, 2011, 15:10
So, I create the empty duct and then an inside solid as the fluid? Inside the empty duct, I mean.
Which is the tutorial? The Ansys tutorial about a HeatSink?
Old   February 26, 2011, 15:33
There are a few tutorials which do solids with heat transfer. Have a look at them. You set up the fluid domain as one domain, and the solid domain as another and link them with an interface.
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
