supersonic flow at inlet and subsonic flow at outlet
Old   March 12, 2011, 23:11
Smile supersonic flow at inlet and subsonic flow at outlet
pradeep
deep is on a distinguished road
Plz help me
i m working on supersonic flow
initial conditions
Mach no.1.5
inlet condition velocity and total pressure -supersonic flow
outlet condition-subsonic flow
i m getting problem is slover
mach no. is going very high then crash it
plz help me whatever condition is required for this type of problem.
deep is offline   Reply With Quote
Old   March 13, 2011, 05:46
Try very small physical time steps to get things started. If that does not work try local time scale factor. Once things are starting to converge go back to physical time scale.
Old   March 14, 2011, 03:58
Default supersonic flow at inlet and subsonic flow at outlet
pradeep
thank you very much Glenn Horrocks,
i tried but still i m getting problem i mention about the boundary conditions and error
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following user files have been saved in the directory |
| F:\run\plasam_101_010: |
| mon |
This run of the ANSYS CFX Solver has finished.
1. Diameter: 1m
2. Mach no.:1.5
3.temp: 1300k
4.Velocity at inlet:1053m/s(cal from mach no.)
5. at outlet condition: mass flow rate:224.3
plz tell me the process its very urgent
plz help me
Old   March 14, 2011, 16:02
ingeniero_82 is on a distinguished road
Originally Posted by deep View Post
Plz help me
initial conditions
Mach no.1.5
hi!! I was once doing a simulation of a supersonic nozzle with argon. it crashed always until I switched the heat transfer option to ''total energy''. in fact, the help says that it is reccommended for any flow with Mach number higher tan 0.3
ingeniero_82 is offline   Reply With Quote
deep
Probelm with supersonic exhaust to ambient newj CFX 2 August 9, 2012 18:01
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 18:42
subsonic inlet or supersonic inlet? mali CFX 0 November 28, 2008 20:57
Outlet BC for subsonic flow in pipe andrea panizza FLUENT 6 May 10, 2003 07:44
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
