March 14, 2011, 19:27 |
How to express a varible at a given point
Ji Guozhao
Rep Power: 15 |
Hi All:
How to express a varible at a specific point in CEL. for example, if i want to express the pressure at the point(x,y,z), is it p@(x,y,z)? or p_x_y_z_coord0? is there any kind hearted one who can tell me the answer? many thanks ahead!!! best regards Ji Guozhao g.ji@uq.edu.au |
March 15, 2011, 10:10 |
Rep Power: 15 |
If you use an expression that includes a variable at specific location, CFX calculates the variable at that location.
If you express your problem in detail, we may find out a solution |
March 15, 2011, 17:26 |
#3 | |
Ji Guozhao
Rep Power: 15 |
Thank you for your reply! I am super happy to that! because if i solved this problem, i can start my project. let me express the problem in detail. I want to simulate gas mass transfer across membrane in a gas separation module.but to the best of my knowledge, only darcy's law is built in CFX, and it is not able to satisfy my requirement, so i have to introduce sink at feed side of membrane and source at permeate side. actually the quantity of sink or source is a function of both pressures at both sides. to illustrate the problem clearly, i also attached a picture. for instance, I want to express the sink. sink_i=C*(P_j-P_i), C is a constant equal to 4.064e-9[kg m^-2 s^-1 Pa^-1]. In source tab-Fluid Mass Flux- CEL expression blank, I only wrote -p*4.064e-9[kg m^-2 s^-1 Pa^-1], treating P_j is equal to 0 pa. but in fact P_j is not constant, it is also changed with position. Can you tell me how to deal with my problem. how can I introduce P_j to express the sink in element i? Best regards Ji Guozhao g.ji@uq.edu.au |
CFX Post: Problems with moving point cloud for changing time steps | spatialtime | CFX | 0 | December 7, 2009 04:56 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
[Other] How to mesh the 1st grid point | lakeat | OpenFOAM Meshing & Mesh Conversion | 1 | October 8, 2007 07:13 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
