NACA0012 - High Resolution - No convergence
Old   March 25, 2011, 06:35
Default NACA0012 - High Resolution - No convergence
bonestruca is on a distinguished road
I can't get my solution to convergence when using the High Resolution solver and medium to fine grids. It only convergences on a very coarse grid. Using the Upwind scheme which lacks accuracy - the solution converges every time !
Mach number is 0.5 and angle of attack 2°. With High Resolution I even get negative pressure forces on the wing in x-direction, totally absurd.
What might be the reasons for this behavior and how do I get it to converge ?
Thank you !
bonestruca is offline   Reply With Quote
Old   March 25, 2011, 15:39
siw
Stuart
siw will become famous soon enough
Could you try running a high resolution scheme simulation with the results from the upwind scheme to initialise the solution?
siw is offline   Reply With Quote
Old   March 25, 2011, 16:09
I tried that and failed.
However I managed to get it to work, I found out that while increasing the number of grid points in the far field and number of inflation layers I did not increase the number of grid points on my airfoil in the same manner. This resulted in long and very thin inflation layer cells, which seem to cause problems with the High Resolution Solver. So I added more points to my profile, decreased the amount of inflation layers and now everything works very well !
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
high resolution scheme az_f CFX 0 November 24, 2010 22:52
larger blend factor or high resolution ? amine CFX 2 March 4, 2008 20:28
upwind vs high resolution Richard CFX 3 February 20, 2006 06:35
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
