Problems with 3D
Old   April 1, 2011, 09:20
Default Problems with 3D
solimcfd is on a distinguished road
Hi! Up till now I have been doing simulations in CFX with only 1 cell in the third coordinate direction. My results were pretty good so i wanted to check what would happen if I extend my model so as to make it three dimensional. I increased the thickness and added more cells in this direction. Using the same setup as before (timestep, accuracy ...) I have tried running this simulation but it always crashes on the first timestep in the first coefficient loop (floating point exception: overflow). Any ideas on what I should do to enable this 3D run?
solimcfd is offline   Reply With Quote
Old   April 1, 2011, 09:29
Raashid Baig
cfd_newbie is on a distinguished road
Just the first step check - are you sure about the integrity of your 3D mesh ?
I mean do you see any error or warning messages for the new mesh ?
cfd_newbie is offline   Reply With Quote
Old   April 1, 2011, 11:56
No, the mesh is is fine. I get no warnings or anything like that. It just crashes straight away. Should I change the setup for the 3D mesh or should it work with the same settings as before?
Old   April 3, 2011, 07:43
Please post the output file around where it crashes.
Old   April 5, 2011, 06:02
Hi! The error looks like this:
| Convergence History |
| Writing transient file 0.trn |
| Name : Transient Results 1 |
| Type : Selected Variables |
| Option : Time Interval |
| Timestepping Information |
| Timestep | RMS Courant Number | Max Courant Number |
| 5.0000E-03 | 0.39 | 7.60 |
TIME STEP = 1 SIMULATION TIME = 5.0000E-03 CPU SECONDS = 2.666E+01
| SOLVING : Wall Scale |
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| Wallscale-Bulk | 0.00 | 2.2E-05 | 1.1E-04 | 43.0 6.1E-01 ok|
| Wallscale-Bulk | 3.25 | 7.1E-05 | 2.2E-03 | 33.6 9.0E-02 OK|
| Wallscale-Bulk | 0.62 | 4.4E-05 | 1.6E-03 | 29.0 9.7E-02 OK|
| Wallscale-Bulk | 0.87 | 3.8E-05 | 1.5E-03 | 29.0 8.8E-02 OK|
| Wallscale-Bulk | 0.84 | 3.2E-05 | 1.2E-03 | 29.0 8.3E-02 OK|
| Wallscale-Bulk | 0.90 | 2.9E-05 | 1.1E-03 | 24.3 9.8E-02 OK|
COEFFICIENT LOOP ITERATION = 1 CPU SECONDS = 7.928E+01
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Overflow |
| Writing crash recovery file |
Details of error:-
Error detected by routine POPDIR
CRESLT = ILEG
Current Directory : /FLOW/NAMEMAP
Old   April 5, 2011, 19:43
Start with a smaller initial time step or a more representative initial condition. This assumes you have set the simulation up correctly, of course.
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 13:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
Some problems with Star CD Micha Siemens 0 August 6, 2003 14:55
Using Fluent for Geophysical Problems Hassid Samuel FLUENT 0 February 23, 2001 07:04
