April 1, 2011, 06:15 |
Can this solution be regarded as converged?
Rep Power: 15 |
I am simulating turbulent flow with conjugate heat transfer and I have specified the following convergence criteria:
RMS residual for mass, momentum and energy equations as 1E-6. AND Conservation target as 0.001% Now I am facing trouble with getting the required convergence. Please refer the attached residual plots. The residual for mass drops below 1e-6. But residual for momentum stabilizes around 1e-5 and that for energy around 5e-6. Regarding the conservation target, the maximum domain imbalance is around 0.006% for H-energy for the fluid domain. Can this solution be regarded as converged. The question may sound stupid as clearly the specified convergence criteria has not been met. But I had no theoretical basis for specifying 1e-6 as the convergence criteria in the first place. Had i specified 1e-5 as the convergence criteria for equations with no criteria for conservation target, I would not have even observed this behavior. |
April 1, 2011, 07:10 |
Stuart
Rep Power: 25 |
It might a good idea to show the same plots again but when it is solved an a finer mesh, apply a gloabl scaling factor to reduce element size, to see if the convergence changes.
April 1, 2011, 09:24 |
Rep Power: 21 |
Looks like good convergence to me! Check the T-Energy imbalance in the solid just to be safe, but I expect it's fine.
April 3, 2011, 06:42 |
Rep Power: 143 |
This question has been asked hundreds of times.... So I wrote an FAQ:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 12:44 |
Philosophy of implicit solution of different regions | Louis Le Grange | OpenFOAM | 0 | October 5, 2009 10:53 |
convergence of solution question | julie | FLUENT | 4 | November 14, 2005 08:35 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
