April 14, 2011, 11:28 |
adiabatic wall boundary condition
George Theo
Hello
I'm using ANSYS CFX v12 to simulate the fluid flow and heat transfer in a rectangular duct. I impose an adiabatic wall boundary condition to the top surface of the fluid domain and a constant heat flux to the bottom one. The logical result is the absence of heat transfer near the upper wall. Instead the results I get show that the fluid is also heated from the top (adiabatic?!) wall. I have checked my boundary conditions and they are ok. Could the problem be related to the mesh? Any suggestions would be highly appreciated. Thanks! |
April 15, 2011, 06:55 |
Rep Power: 143 |
No, an adiabatic wall should not heat no matter what you do.
What makes you think the adiabatic wall is heating it? |
April 18, 2011, 09:06 |
George Theo
Thank you for your swift reply!
Unfortunately, I didn't interpret my results correctly. The fluid is heated due to the effect of the lateral wall. I was confused because the heating took place near the vicinity of the upper boundary. Sorry to trouble you! |
adiabatic wall, heat transfer, rectangular duct |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
How To Convert Fluid wall in Solid Wall Boundary Condition | RGN | FLUENT | 4 | March 31, 2009 04:43 |
Variable temperature wall boundary condition | Virginie | FLUENT | 2 | October 2, 2007 09:23 |
