interface heat transfer
Hello everyone.
I have a question about heat transfer between two solid domains. I need to compare two cases. First one with no heat transfer between two domains and second one with heat resistance on the surface. Is it right when I don't check the box in "additional interface model" (heat transfer) and no heat transfer is desired?? Thanks a lot for any question |
The default for the interface is ideal contact. What the additional model does can be seen, when you play around with the options.
