about reference pressure
Old   May 13, 2011, 10:25
Default about reference pressure
adam2008 is on a distinguished road
I have a question about reference pressure. In definition of idea gas, there is a tab of "reference state", and "Air Ideal Gas" in CFX material library uses 14.7psi (1atm) as reference pressure. In domain setting, we also need to set a reference pressure. My question is,
Do I must set this reference pressure in domain setting as 14.7psi also if I use "Air Ideal Gas" as fluid?
I usually set reference pressure in domain setting as "0 psi" for convenience because I am deal with absolute pressure (psia) all the time. I ask because I happend to read one sentence in CFX-help as below
"When using an ideal gas, it is important to set an appropriate reference pressure since some properties depend on the absolute pressure level."
Thanks for your answer
adam2008 is offline   Reply With Quote
Old   May 17, 2011, 08:03
Shenren Xu
Shenren_CN is on a distinguished road
Originally Posted by adam2008 View Post
You have to, if you want to calculate compressible flow. Because the flow variables depends on the absolute value of the pressure (reference pressure in the domain). I suppose you "usually set reference pressure to 0psi" because you usually run incompressible flow solver, where the reference pressure does not matter at all (meaning it does not affect your velocity field).
Shenren_CN is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
specify a reference pressure point in FD method? Rui Main CFD Forum 10 August 30, 2010 08:50
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
Compiling new Solver with wmake lin123 OpenFOAM 3 April 13, 2010 14:18
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
