flow visualisation behind an impulsively started cylinder... |
May 2, 2011, 01:17 |
vetriselvan
Rep Power: 16 |
Hi all,
I'm trying to compare the flow patterns of the early stage of development of the wake behind an impulsively started cylinder with the experimental results done by Bouard and Coutanceau 1980. I'm not able to get the flow pattern at t*=1(as per the paper), even though I'm able to get the other flow patterns(but at different t*s).Could anyone please help in this regard??? I've attached the cfx simulation results. Thanks in advance...Regards, vetri |
May 2, 2011, 07:45 |
Rep Power: 143 |
May 9, 2011, 23:02 |
@ vetri
Mayank Ojha
Rep Power: 14 |
Can you tell me what are you exactly comparing your results to ??? I am also tying to do similar stuff. May be I can help if you explain your problem a bit in detail.
-Mayank |
May 12, 2011, 00:59 |
vetriselvan
Rep Power: 16 |
Hi Mayank,
Thanks for your interest in the problem... I'm trying to match the t* values and the flow pattern behind the cylinder.I could not match any of the t* values. But I'm able to get three patterns out of four as per the thumbnails posted. I'm calculating t(time step) values as follows. Regards,t=(t*)D/vwhere t-> time step input in cfx vetri |
May 16, 2011, 01:57 |
@ Vetri
Mayank Ojha
Rep Power: 14 |
I did analysis over a stationary and a moving cylinder for quite a long time now. From what I understand is that the formation of vortex depends upon the numerical instability build as time passes. For example, If you have a single cylinder which is completely structured mesh, the vortex formation takes time, if you plot Cl vs time you realise it. On the other hand if you use a triangular (2-D) mesh, the vortex vormation takes place quicker because the mesh is not totally symmetrical about the horizontal. Also if your initial condition is something like Uinitial=c*y (c=some constant & y=domain ht.) the vortex shedding is much faster. When it comes to unstable solutions like vortex shedding from cylinders always measure factors like Pr. distribution, lift coeff, drag coeff only once the cylinder has reached the quasi steady state. I have never heard anyone comparing the time values from experiment to numerical simulations especially when it comes to vortex shedding/formation Hope this helps. -Mayank Ojha |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
flow around a cylinder | pXYZ | Main CFD Forum | 14 | July 25, 2011 10:05 |
1 Was FSI for a flow over a cylinder | vmlxb6 | CFX | 17 | May 16, 2011 02:29 |
flow around circular cylinder...plz help | yousef | FLUENT | 4 | March 28, 2006 11:01 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
