setting Boundary condition for additional variable |
May 18, 2011, 05:04 |
anonymous
Rep Power: 15 |
HE ALL ;
I want to set Boundary condition for pollutant ( CO) as aditional variable my line source is in the ground a street at level z=0 . my Boundary parts are INLET, OUTLET, symetry ( SIDES 1 et 2) , GROUND , TOP , SOURCE the emission rate from the source is 0.0001 Kg/s. If any one experienced can help |
May 18, 2011, 06:08 |
Rep Power: 143 |
Sounds straight forward. Have you done the tutorials? That will give you some tips on how to get started.
Or what specific problem do you have in setting it up? |
May 19, 2011, 04:44 |
anonymous
Rep Power: 15 |
thanks ;
firstly, I took a look in tutorial , there is an exemple wich treate smoke dispersion. My case deel with a tracer gaz (SF6) realised from a line source within a street. the emission rate is 0.0001 kg/m^3. To simulate the concentration of SF6 I used an additional varaiable CSF6 with a transport equation . I choose for CSF6 BC : INLET Value CSF6 =0 OUTLET ZERO FLUX SYMETRY ( SIDES) ZERO FLUX TOP ZERO FLUX GROUND AND LINE SOURCE CSF6 = 0 the simulate concentration CSF6 = f(Z) seems wrong because the minimum conentration value was located at level z=0 wich is not correct. |
Display Modes | |
Setting boundary condition for C-grid airfoil | quarkz | FLUENT | 0 | December 28, 2010 14:37 |
Variable boundary condition | Sae. kil | CFX | 0 | November 19, 2008 11:00 |
Boundary condition setting for water hammer proble | yizhou | FLUENT | 1 | October 12, 2007 12:16 |
Variable temperature wall boundary condition | Virginie | FLUENT | 2 | October 2, 2007 09:23 |
Variable Boundary Condition | Malcolm | CFX | 10 | June 23, 2005 06:27 |
