Unstructured Mesh using Mesh adaption
Old   May 31, 2011, 06:16
Default Unstructured Mesh using Mesh adaption
Siddharth
sidzishere is on a distinguished road
I have been trying to perform mesh adaption on a structured hexa-mesh using CFX and the resultant mesh is always without any hanging nodes. This in turn produces a large expansion ratio across cells which makes the results to lose convergence after adaption. Is there some way to adjust the adaption parameters to make the mesh adaption behave better. If the same adaption is done using fluent, the mesh generated is more uniform without large expansions because fluent allows the generation of hanging nodes.
Could someone help me with this issue.
Thanks a lot in advance
sidzishere is offline   Reply With Quote
Old   May 31, 2011, 10:18
A.R. Baserinia
baserinia is on a distinguished road
Hi, You're question is not very clear. When you refine an element, the expansion ratio at the intereface of refined and unrefined regions will be 2. How is that different between Fluent and CFX?
The only thing about CFX is that, if you apply the adaptation to a structured mesh, at the intereface of refined/unrefined regions, you get tets. So if you want a high-quality mesh, your best bet would be to design a non-uniform mesh manually.
baserinia is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[Other] 2D unstructured mesh majidhojjat OpenFOAM Meshing & Mesh Conversion 1 May 14, 2009 17:09
Structured and Unstructured mesh Jingwei FLUENT 0 March 2, 2009 21:29
[Commercial meshers] Unstructured hex mesh lr103476 OpenFOAM Meshing & Mesh Conversion 12 November 24, 2006 05:56
2D Modelling using unstructured mesh Yingchun CFX 8 December 12, 2005 06:05
