May 23, 2011, 17:51 |
What is ANSYS MFS ???
Mayank Ojha
Rep Power: 14 |
Hello all,
I would like to know what is a MFS. This video in youtube (link below) which shows the flow over a cylinder is done using ANSYS MFS. I am trying to do the same thing. http://www.youtube.com/watch?v=bCqMXiXCrBY Thank you very much. |
May 24, 2011, 09:51 |
Rep Power: 21 |
MFS = Multifield Solver. It has nothing to do with CFX. MFS is used to couple different elements together in ANSYS. In this case I would guess some structural or rigid body elements for the cylinder were coupled with some fluid elements. It appears that the flow field is solved, so I would assume the fluid elements used are based on the old Flotran CFD solver. Flotran really isn't used anymore, but it's still there inside ANSYS.
Command Line Run for ANSYS | Liaquat | ANSYS | 11 | April 19, 2018 09:49 |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 12:11 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 09:16 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 12:59 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
