June 5, 2011, 06:11 |
CHT mesh
William Shaw
Rep Power: 15 |
Hi everyone, I need to use ICEM CFD to create a mesh for CFX CHT(Conjugate Heat Transfer), do I need to mesh the solid part? If so,how to mesh?
June 5, 2011, 07:10 |
Rep Power: 143 |
Yes, you need to model the solid part. Mesh it using the same techniques used for a fluid mesh. But remember as the equations to be solved in a solid domain are linear and simple you can usually mesh much more coarsely and with poorer quality, but on the other hand a solid domain node only has one equation to solve compared to the 7 or more often solved in a fluid domain so the cost of solid domain meshes is low... so why not mesh finely.
Remember the solid timescales are usually far slower than fluid timescales so rapid fluid transients result in very thin regions of high thermal gradients at the surface of the solid. If this is important you should consider an inflation like mesh at the surface to capture the steep gradients. |
June 5, 2011, 07:12 |
#3 | |
William Shaw
Rep Power: 15 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 10:40 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 01:10 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
