Initializing simulation from previous results File (CFX)
Hello All,
I am working on CFX and my mesh every time is changing a bit and i want to use previous result file. Could you pls help me out...how can i do this? Best Regards, |
Use the initial condition interpolation stuff. It is all built-in to CFX. It can handle non-matching grids.
Thanks for reply. yes i got it its available in CFX-pre, Exwcution control. Initial value and res file.
I have one more query. I want to stope solver by the efficiency smoothness. That means I want to see efficiency curve if its not changes than want to stope my solver. I found in CFX solver control there is an option interrupt control and i can define efficiency expression. But How can i take difference of two iterations (smoothness)? Hope you understand my question. Regards, |
Found solution inCFX pre under Executaion control, there is an option initial value specifiction,. By clicking on it we can give path of result file.
There is an other way through CFX solver manager by using interpulatin. Regards, |
