Who understand Bump Tutorial?
Old   May 18, 2012, 12:36
Default Who understand Bump Tutorial?
mariam.sara is on a distinguished road
I need to know is UpH in bump tutorial represents the free surface height at inlet while DownH is the free surface level at outlet? I am really confused about it may somebody answer me please?
mariam.sara is offline   Reply With Quote
Old   May 19, 2012, 01:11
Default Hi
Danial
Danial Q is on a distinguished road
Yes, that is what tutorial states. UpH is for inlet and DownH is for outlet.
Danial Q is offline   Reply With Quote
Old   May 20, 2012, 10:44
Thanks Danial for the answer. In my case the lower phase is flows with a velocity differ from the upper phase velocity. In bump tutorial they only use single velocity at inlet I want to set the two velocities at inlet together for both phases. As I know from the guys on the forum this is possible unless the two phases never mixed and I can still use homogeneous model . Someone said that If the free surface is at z=10 mm, then for z<10 mm I need to define velocity=0.5 [m/s], and where z>10 mm I need define velocity=1[m/s]? I aware that I need use a CEL expression for it but I am a beginner with CFX may you please type how the CEL expression for this case become? Knowing that I read the examples mentioned about CEL expression at the documentation but never find similar one to my case?
Thanks a lot
Mariam
Old   May 20, 2012, 17:34
Default HI
Danial
it would be like this;if you have one
for inlet and for both velocities :
if(z>=10[m/s],if(z<=0.5[m/s],1[m/s],0.5[m/s],0[m/s])
it should work, i think so. try it and if it does not ,post it here and you can get suggestions from anyone.
Old   May 21, 2012, 01:49
HI Danial I not understood something in your last expression? From where you bring 0 [m/s] velocity? I never set like this velocity at my last post? furthermore I think there is error in your expression it must be as follows as I think:
if(z>=10 mm,if(z<=10 mm,1[m/s],0.5[m/s])
is it right?
another thing how can I define this expression in my simulations for the velocity at inlet? in Bump tutorial they give each expression a known symbol (like UpH,DownPre,.......etc) should I give symbol for this expression too?
Old   May 21, 2012, 23:59
Default HI
Danial
yes , u will hv to give name like " V "for velocity while creating expressions, earlier expressions must have an error because, units will be written such as; [m s^-1] rather [m/s].
Zero velocity means if your fluids have velocities as u defined, they will take the value of your velocity proposed (1 or 0.5]. Otherwise, if they dont fall in those ranges, velocity will be considered zero.
Insert > expressions > [name wteva u like]
if(z>=10[mm],if(z<=0.5[mm],1[m s^-1],0.5[m s^-1]),0[m s^-1])
Old   May 22, 2012, 10:31
Depending on the expression you mentioned I type the following statement:
if(y>0.01 [m],if(y<=0.01 [m],12.5 [m s^-1],0.0066 [m s^-1]),0 [m s^-1])
where y vertical distance
0.01 m is the free surface level
when I try test the expression before run in cfx-pre it gives zero velocity everywhere along y so what the problem? may somebody tell me? is the expression incorrect?
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 11:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
