Mass flow rate
Old   August 9, 2011, 00:15
Default Mass flow rate
sepideh
sepidecent is on a distinguished road
I'm running simulation in CFX-Eulerian-Eulerian approach in a rectangular,vertical box with a slot at the top for curtaining particles.I want to achieve mass flow rate at each height by putting plane (horizontal plane).At discharge point the mass flow rate is fine when i extract my data based on X,Y,Z and massflow and sum all mass flows within the plane it gives me the exact amount of mass flow I put in setup for solid inlet boundary condition but gradually by coming down to the base of the box it gives me some negative mass flow rates and at the base plane all of my mass flow rate are negative.I don't know what is the reason.
Cheers,
Sepideh
sepidecent is offline   Reply With Quote
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 20:33
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
