September 14, 2011, 00:18 |
Flow Through an Immersed Solid !
morteza
I am using the immersed solid to model a valve. When the valve is closed I expect it stop the flow of water behind it but when I check the stream lines and the velocity contour it seems like the flow is passing through the valve. What do you think is wrong with my model ?
September 14, 2011, 06:49 |
Rep Power: 143 |
The immersed solid approach uses a factor to slow the flow, I can't remember its name. Have you set this factor high enough?
September 14, 2011, 10:27 |
Rep Power: 20 |
It's "Momentum Source Scaling Factor". Try a value of 100, and also set the expert parameter "smooth inside ims = t" to improve convergence when a high scaling factor is used. You'll have to type that parameter in the command editor since it's not in the GUI.
Having said this I have found "leakage" occurs when trying to block the flow using an immersed solid. The problem is that the solver applies a scaling factor, but when the velocity is zero the scaling factor doesn't do much. I guess just see how high you can make the scaling factor before convergence becomes too difficult. |
May 25, 2012, 07:05 |
belgacem
Hi Friends
I am also studying immersed boundary method and and try to simulate a block falling in the water. I am using "immersed solid" then rigid body 6DOF and I let it fall freely but it can't stoped in the bottom where the velocity must be zero. I give a density to the block and i let it fall freely under gravity. Noted that the rigid body is defined as an immersed solid. i have specified a stationary coordinate frame that has its origin at the center of mass of the physical rigid body. Another fixed coordinate frame was specified related to the water at rest. What can I do to stopped the rigid body in the bottom where the potentiel energy must be zero? thank you! |
April 7, 2013, 05:56 |
if i did as you said,i occoured an error!why?
#5 | |
ERROR #001100000 has occurred in subroutine EPORT_OBSOLETE_PRM. Message: The following unused Expert Solver Parameter was found: || SMOOTH INSIDE IMS | The parameter may be incorrectly spelled. can you tell me what's up with it ? thank you ! |
immersed solid |
Question about immersed solid method in CFX | spwater | CFX | 6 | May 24, 2012 14:05 |
Gas solid flow in a pipe with 90 bend | pandaba | FLUENT | 0 | September 14, 2010 02:43 |
Modeling of solid domains in fluent, no fluid flow | Satish Perivilli | FLUENT | 2 | December 1, 2005 12:41 |
flow thru parallel plate with solid heat generater | cindy | FLUENT | 1 | October 10, 2005 23:54 |
Flow through solid cells | Julie Polyakh | Siemens | 1 | September 6, 2003 09:18 |
