mesh stiffness of FSI
Old   September 20, 2011, 03:13
Default mesh stiffness of FSI
colopolo is on a distinguished road
Dear All,
I am trying to run vibration of plate using fsi (to find critical flutter velocity)
I have a big problem about folded mesh. I have been searched this problem in here and google but I cannot solve it.
I did control mesh stiffness of increase near boundary and increase near small volume. I used 1 or 10.
But every running case has folded mesh.
I really have no idea how to control foled mesh.
Please welcome any ideas for this problem
Thanks in advance
colopolo is offline   Reply With Quote
Old   September 20, 2011, 04:06
Matthias Voß
mvoss is on a distinguished road
hey,
you need to create an expression for the stiffening around the corners. smth. like (sqrt((x-x0)^2+(y-y0)^2))^4 with x0/y0 being the coordinates of the current location of one corner e.g. (itīs a circle function to the power of 4 to make it really hard at the pref. point).
Create an expression for every point or even for smth. like a line function and overlay them by summation in a final expression for the stiffness.
The tricky thing is to update the x0/y0 every timestep. There is a solution for this ... smth. dealing with monitorpoints.... i donīt remember exactly.
neewbie
mvoss is offline   Reply With Quote
Old   September 20, 2011, 04:10
Originally Posted by neewbie View Post
hey,
neewbie
Thanks you your response. I am not familiar with expression formula.
Do I just put the above equation in the mesh stiffness term of CFX?
Could you tell me a little bit detail about how to create it?
This is wind-induced vibration problem so how to define x0 and y0?
Sorry to bother you.
Thanks.
Old   September 20, 2011, 04:14
Matthias Voß
take a look at the tutorials ... creating the expressions is straight forward.
create an expression stiff1, stiff2 with the app. expressions for x1,y1,x2,y2 and combine them to letīs say: stiffness=stiff1+stiff2
Old   September 20, 2011, 04:28
Thanks.. I will try to do that. I really appreciate your help
Old   September 20, 2011, 06:18
Matthias Voß
... (sqrt((x-x0)^2+(y-y0)^2))^4
it has to be \sqrt{(x-x_{0})^{2}+(y-y_{0})^{2}}^{-4}
Old   September 20, 2011, 18:03
Very appreciate it. I tried to make CEL expression but I do not have no idea how to define x0 and y0.
Does this x0 and y0 indicate the coordinate of edge of plate?
if you help me more,. thank you very much.
Old   September 20, 2011, 18:47
I changed more simple tetra mesh and attached a mesh image just before error.
I supposed the error occur near the plate but, in my case, large mesh deformation occur between inlet and plate.
Does anyone has any ideas?
I am still trying to make CEL which you mentioned.
Old   September 21, 2011, 09:28
Matthias Voß
just guessing... but wouldnīt smth. like C*f(x) for the stiffness solve this similar to the idea above? Isnīt there a "stiff near bc" option?
Old   September 21, 2011, 19:43
Thanks for ur response. There is "stiff near bc'' option. I also controlled 'stiff near bc' as 1, 10, and 100. but nothing changed.
Old   September 22, 2011, 03:52
Darren Leong
Darren Leong is on a distinguished road
Leave the exponent value at 10. Looking at your pic, the mesh in the farfield is skewing. Try enlarging the domain or have a coarser mesh in the farfield which will allow more deformation overall
Darren Leong is offline   Reply With Quote
Old   September 22, 2011, 04:15
Thanks !! I will try to do that and leave the result in this thread..
Very appreciate it
Also, I have another problem. the plate moves at x -direction even if the plate is constrained in x-dir.
I onle let it free moving at y-dir and rotating at z-dir but it moves also x-dir.
Old   September 22, 2011, 21:50
It looks ok. but Force can not converge after some time stpes.
Force is increasing more and more.. how to control force convergence?
FSI Mesh stiffness Andrew.Coughtrie CFX 3 July 29, 2011 03:50
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Mesh Stiffness Option for Mesh Deformation Ste_Lakey CFX 3 January 19, 2006 16:33
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
